SERIES 2
Production years: 1973 - 1979
1973 brought about the XJ Series 2 models with the need to amend the design primarily for safety regulations in the USA. Front bumpers were raised which meant changing the radiator grille and lighting. Side impact bars were fitted to the doors and the bulkhead was sealed off from the cabin area. A new dashboard and other trim changes saw the range also expand with another new engine configuration 3.4 litres plus the 4.2 and 5.3 litre engines, plus Jaguar and Daimler models, long and short wheelbases, Vanden Plas and even a beautifully styled two-door pillarless coupe models.
MODEL SUMMARY
MODEL TYPE
PRODUCTION DATES
ENGINE RANGE:
0 - 60 MPH:
TOP SPEED:
XJ Saloons
1973 - 1979
3.4 Litre Series Saloon
3.4 Litre Series Saloon - 10.9 seconds
3.4 Litre Series Saloon - 117 mph
4.2 Litre Series 2 Saloon
4.2 Litre Series 2 Saloon - 8.9 seconds
4.2 Litre Series 2 Saloon - 125 mph
5.3 Litre Series 2 Saloon
5.3 Litre Series 2 Saloon - 7.8 seconds (Note All these specs are for Fuel Injected models)
5.3 Litre Series 2 Saloon - 147 mph
Series 2 Technical Specifications
Technical Information
Engine Statistics
Engine (cc)
3442
4235
5343
Bore and Stroke (mm)
83 x 86
92.7 x 106
90 x 70
Compression Ratio
8.8:1
8:1 (7:1/9:1 optional)
9:1
BHP
161
170
285
@RPM
5000
4500
5750
Torque (lb ft)
189
231
294
@RPM
3500
3500
3500
Fuellling
2x SU carbs
2x SU carbs
4x Stromberg carbs, later fuel-injection
Engine Performance
Top Speed
117 mph
125 mph
147 mph
0 - 60 mph
10.9 seconds
8.9 seconds
Fuel Consumption
16.7 mpg
15 mpg
13.2 mpg
model Specifications
4-speed all synchro BW 3-speed auto
BW 3-speed auto Later GM 3-speed auto
Wheel Size (in)
15, steel/chrome
15, steel/chrome
15, steel/chrome
Suspension (Front)
Ind semi-trailing wishbones, coil springs, anti-roll bar
Suspension (Rear)
Ind lower wishbones/upper driveshaft link, radius arms, coil springs
Brakes
4-wheel disc, rear inboard
Model Dimensions
Length (in)
189.5 (194.75 long-wheelbase)
Width (in)
69.25
69.25
69.25
Height (in)
54
54
54
Wheelbase (in)
108.75 (112.75 long-wheelbase)
Front Track (in)
58
58
58
Rear Track (in)
58.5
58.5
58.5
Weight (Cwt)
32
33 (34 long-wheelbase)
35 (36 long-wheelbase)
OPTIONAL EXTRAS
All Models
  • Flush fitting fog/spot lights (standard on Vanden Plas)
  • Laminated windscreen (standard on Vanden Plas)
  • Sundym tinted glass (standard on Vanden Plas)
  • Front seat headrests (from 1969) (standard on Vanden Plas)
  • Witter tow bar
2.8 Litre Series 1 Saloon
  • Heated rear screen
  • Overdrive for manual geabox
  • Automatic transmission
  • Power-assisted steering
  • Electrically operated windows
  • Front seat belts, or front and rear
  • Two choices of radio equipment
  • Chrome wheel rimbellishers
  • Wing mirrors
  • Mud flaps (de luxe saloons)
4.2 Litre Series 1 Saloon
  • Heated rear screen (standard from 1972)
  • Air-conditioning
  • Front seat belts, front and/or rear
  • Two choice of radio equipment or radio/cassette or cartridge unit
  • Philips radio/cassette and recorder with microphone
  • Electrically operated radio aerial
  • Wing mirrors
  • Mud flaps
5.3 Litre Series 1 Saloon
  • Air conditions (standard on Vanden Plas)
  • Front seat belts (standard on Vanden Plas) and/or rear
  • Two choice of radio equipment or radio/cassette or cartridge unit (standard on Vanden Plas)
  • Chrome-plated ventilated steel wheels
  • Wing mirrors (not Vanden Plas)
  • Passenger-side remote door mirror (Vanden Plas only)
  • Mud flaps
Chassis Numbers
Model
Driver Side
Chassis No. Commenced
Number made
Jaguar XJ6 2.8
RHD
1G1001
13301
Jaguar XJ6 2.8
LHD
1G50001
6125
Jaguar XJ6 4.2
RHD
1L1001
33467
Jaguar XJ6 4.2
LHD
1L50001
25505
Jaguar XJ6L 4.2
RHD
2E1001
583
Jaguar XJ6L 4.2
LHD
2E50001
1
Jaguar XJ12
RHD
1P1001
720
Jaguar XJ12
LHD
1P50001
1762
Jaguar XJ12L
RHD
2C1001
750
Jaguar XJ12L
LHD
2C50001
3
Daimler Double Six
RHD
2A1001
Daimler Double Six
LHD
2A50001
CLUB EVENTS
CLUB NEWS
Parade cars for Wroxall
MODEL CONTACTS
Keith Parrington
XJ Series Forum Co-ordinator
