Buzzing sound
Moderator: steveisleofwight
Rogue_Trooper
Buzzing sound
Postby Rogue_Trooper » Wed May 29, 2019 10:08 pm
Evening all, I've noticed a buzzing sound (electric(onic) before anyone mentions bees/wasps etc ha ha!
I noticed it when muting my radio to make a call.
It seems to be coming from around the steering wheel general area. Anyone else had this problem/annoyance?
Car is an 08 2.2D auto
Phil.
Astromorg
Re: Buzzing sound
Postby Astromorg » Thu Jun 06, 2019 10:39 pm
Sorry to be so late in getting to this!
Almost certainly the noise you report is coming from behind the little 1 inch square grill just to the side of the steering column. In there is a small fan unit that takes in cabin air and measures its temperature to inform the climate control system.
The grill can be pulled out and any fluff extracted from the unit to see if that helps. Be careful not to damage the sensor itself
2005 XK8 4.2-S Coupe
2005 X type 2.5 SE Auto
Rogue_Trooper
Re: Buzzing sound
Postby Rogue_Trooper » Sun Jun 16, 2019 4:12 pm
Many thanks! gave it a blast with some canned air, and although still present It's not as loud. Will try a small amout of WD next in case of dy fan fan bearing.
Phil.
