Rack bush removal tool required
Jon
Postby Jon » Wed May 17, 2006 8:08 pm
Does anyone have one of these they could sell / lend me? I've had a word with classic spares but they don't have them in at present.
Thanks.
CLEAN old '87 XJ-S 3.6 manual (for sale!)
If no-one buys it soon, its going on classic insurance!
'96 XJR manual (the green monster)
Postby ptjs1 » Wed May 17, 2006 9:09 pm
Hey Jon, what happened to the plastic washer packing routine that you tried?
rgripp
Postby rgripp » Thu May 18, 2006 5:57 pm
Long bolt + undersize/oversize socket combination.
Telsmoneypit
Postby Telsmoneypit » Thu May 18, 2006 6:43 pm
I've got one. Send me a PM with your details and I'll post it off to you.
I would like it back however!
Terry
XJ-S 3.6 coupe, Manual, Sportpack, Signal Red
Jon
Postby Jon » Fri May 19, 2006 5:42 pm
Thanks for the replies guys, while the plastic washer thing was a great improvement, I think the bushes themselves are past it. Might have failed the MOT without them. I think it would be very good mod with the standard bushes in new state.
Tel - you have PM!
Telsmoneypit
Postby Telsmoneypit » Tue May 23, 2006 11:04 pm
Jon, I tried to send a you a PM but I met with a 'general error' :roll:
So looks like I'll have to post it here...
Hi Jon, I finally found the bush extraction tool (back of the shed as usual :roll: ) there is one problem though....
The main bolt is bent making the thing useless!
I am attempting to locate (or make) a replacement. The original bolt was 100mm long (M8 thread) but so far the longest I have managed to get is an 80mm long bolt, which I don't think is long enough to do the job.
Question is: Can you wait until I get this sorted or would you prefer I send the tool with the shorter bolt so you can give it a try?
You may be able to source a 100mm long M8 bolt in Nottingham. If you can, then no problem, I'll post the thing up to you as is..
Let me know what you'd prefer.
Tel
Jon
Postby Jon » Tue May 23, 2006 11:41 pm
Hi terry,
I'm sure we'll be able to cobble something up / 'borrow' something(working at a large assembly shop has its advantages) . If you send it as is including the bent bolt that would be great.
Thanks! 8)
poprivet
Postby poprivet » Sat Nov 11, 2006 3:15 pm
I was hoping to replace my (slightly perished) sportspack bushes with urathane ones but came across a problem. Unlike the original design, the sportspack bushes have a 'top-hat' shaped steel inner, the diameter of the rim being as large as the rack itself, hence not being able to use an extractor. It looks like the rim will need to be sawn off before extracting the rest of it in the usual fashion, difficult in-situ as I don't want to mark the rack in any way. Has anyone here found a way of removing the bushes without dropping the rack off the car?
Pop
1988 3.6 XJ-S coupe
'Remember that the value of your investment can plummet as well as fall'
HerefordMark
Postby HerefordMark » Sat Nov 11, 2006 7:11 pm
Pop,
My XJRS has the same bushes. I got mine out using lots of WD40, and a suitable socket to drive them with a hammer. Neither the bushes or the rack were damaged (in fact I am going to have to refit them as they are still miles better than the so called sport poly bushes I got from an allegedly expert Jag parts supplier).
HM
