Steering rack leak
Shaun
Steering rack leak
Postby Shaun » Tue Apr 10, 2012 1:33 pm
Hi, I have a small leak of power steering fluid from where the steering column shaft enters the top of the steering rack on my pre HE 5.3 V12. The steering rack is otherwise in good condition with no wear/play. Does anyone know if there is a seal that can be replaced or is the only answer a replacment steering rack?
Thanks.
Jaguar 1962 MK2 3.8
Tuffareo
Re: Steering rack leak
Postby Tuffareo » Tue Apr 10, 2012 2:05 pm
Hi Shaun,
Before running to the expense of replacing the rack try the following: -
Lucas Stop Leak. £8 for a 355ml bottle from local motor factors.
I cannot vouch for it, but there is a guarantee of sorts.
1987 XJS 3.6 Auto Cabriolet
poprivet
Postby poprivet » Tue Apr 10, 2012 6:02 pm
Stop fluid won't help, the seal gets cooked by the heat from the manifold.
The seal is part No. AEU1248 about £4. Fiddly to do, especially on a V12 but it will cure the problem.
I had to change mine some years ago.
1988 3.6 XJ-S coupe
'Remember that the value of your investment can plummet as well as fall'
Postby Brakebuster » Tue Apr 10, 2012 6:51 pm
as pop says ,
right pig to do , but worth it
2004 2.1V6 X-Type Saloon in platinum silver for the good wife
used to have
1999 4ltr Sovereign XJ8 in Seafrost
Shaun
Postby Shaun » Fri Apr 13, 2012 1:15 pm
Thanks all for the replies, think I'll try the new seal first as there rest of the rack looks in very good condition. Fingers crossed!
Jaguar 1962 MK2 3.8
