Steering rack reinforcing bracket
Moderators: davidr, BigCatXJS, dhdove
Carnut72
Postby Carnut72 » Sat Dec 30, 2017 2:21 pm
Hi all,
Following on from refurbishing my '83 HE front suspension and steering, I have fitted poly bushes to the steering rack.
I have found upon reassembly, that the reinforcing bracket do not slide easily over the bushes.
Just in case I have got it wrong, the bracket fits on the drivers side with the thick end of the bracket upwards. Is this correct?
Also, is the bracket required? There were no instructions in the bush kit!
Many thanks in advance,
Mitch
davidr
Re: Steering rack reinforcing bracket
Postby davidr » Sat Dec 30, 2017 3:49 pm
Mitch - do you mean this assembly?
Carnut72
Postby Carnut72 » Sat Dec 30, 2017 5:38 pm
Yes, it is item 1 on the diagram.
I have trial installed the bracket with the 'thicker' walled section uppermost.
Is this correct? I have also deleted the shims as I understand that the poly bushes do not require them?
Thanks in advance,
Mitch
Carnut72
Postby Carnut72 » Sun Dec 31, 2017 9:30 am
If all else fails, I will remove the extra bonded washer and fit it without. :D
Carnut72
Postby Carnut72 » Sun Jan 07, 2018 2:19 pm
I removed the washer to reduce the bracket thickness as it was too wide with the poly bushes.
As you can see it now fits perfectly!
Washer removed-just some paint to touch up required
Nice fit now
