Can't find a condenser!!
Postby davidr » Wed Jan 14, 2015 8:49 pm
Help!! I'm trying to find a new condenser radiator for my 1989 V12 but it's proving difficult from the usual sources. The part number is CBC8540 but I'm also told that the one for the 6 cylinder cars ( CBC8541) can be made to fit.
Anyone got any ideas?
1996 XJS Celebration Conv. (shown on the JEC stand at NEC Nov 2015)
2001 XKR Convertible
Re: Can't find a condenser!!
Postby J44EAG » Wed Jan 14, 2015 8:58 pm
Try this, David.
http://www.justjagsuk.com/product_detai ... 341/81281/
I got this just by typing the part number into Google. That often works and saves a trawl though complete site lists and catalogues.
Hope that helps.
Postby davidr » Wed Jan 14, 2015 9:05 pm
Thanks Mike. I'll give them a ring in the morning. I have done the Google and ebay search thing and plenty of people list the part but when they go to get one from their usual supplier they come back and say "sorry - can't get that - supplier says out of stock until mid- March"
Anyway, haven't tried this one so will give it a go
David
Postby Brakebuster » Wed Jan 14, 2015 9:32 pm
i have a brand new one David
genuine Jaguar , bought brand new by me from jaguar, never fitted or used
PM me
2004 2.1V6 X-Type Saloon in platinum silver for the good wife
used to have
1999 4ltr Sovereign XJ8 in Seafrost
Postby davidr » Wed Jan 14, 2015 10:20 pm
BB - trying to PM you but for some reason it won't go through
Postby Brakebuster » Wed Jan 14, 2015 10:52 pm
hmm , should do , only 44% full , lol
BB :mrgreen:
used to have
Postby davidr » Wed Jan 14, 2015 10:58 pm
Won't go through. Could you try sending me one please?
Postby Brakebuster » Wed Jan 14, 2015 11:11 pm
test sent
used to have
robv12
Postby robv12 » Thu Jan 15, 2015 11:24 am
try these guys as well
http://www.nargroup.com/
the do all the parts for Jaguar Heritage
Postby davidr » Wed Jan 21, 2015 10:52 pm
Got one! Many thanks to BrakeBuster! Cheers mate!! :D :D
The one that BB had was a CBC8451 which is the 6 cylinder version but it could be made to fit with a little adjustment
Connection to receiver/dryer. Old one at the back.
The pipe that needs to be adjusted (and some bloke's shoes!)
New and old condenser together. Scabby old one at the back!
Postby davidr » Wed Jan 21, 2015 11:13 pm
Now a few pictures of the car going back together. New receiver fitted and the pipe going to compressor having been adjusted. It is an alloy pipe and relatively easily bent by hand - just have to be careful not to strain the joints or flatten the pipe.
Took the time to strip and repaint the header rail, put a new receiver/dryer in and renewed all the fixings just to tidy everything up.
Just have to tighten everything up now and put the bonnet back on. Next big step is to go and get it vacuum tested. If that's OK I'll also get it pressure tested because sometimes a vacuum will pull a seal in and become gas tight but a pressure will be a more realistic test. If all that checks out then I'll get some gas back in and give it a go! The car has now had a new condenser, compressor, receiver/dryer, hoses and expansion valve over the years - better bloody work now!!
Pipe bent round to meet pipe from compressor
Condenser in place
Finished installation with newly painted header rail, new receiver and fixings
Postby Brakebuster » Thu Jan 22, 2015 5:08 pm
that looks good , and not to difficult to alter the pipework either by the looks
unless already converted, you can use R24 for the gas , its drop in with no requirement to alter any valves etc , the system takes just under 1kg , and I have a 12kg bottle here :wink: should you need it
otherwise its about £100 I think for a system refill...?
used to have
Postby davidr » Thu Jan 22, 2015 5:25 pm
It's already converted to the new gas. I've changed practically all of the system so I got valve adapters and an expansion valve calibrated for R134a as I was doing it.
£100 for a recharge is quite steep I think. I have a useful friend so I get "mates rates". Just pay for the gas!
When I was stripping down and repainting the header rail I was thinking that I only did the job recently and telling myself off cos it had deteriorated so quickly. Then I had a think about it and realised that it was probably about 12 years ago! The car has now got to the stage that I'm doing things again. Forth Bridge comes to mind!! :D
Anyway, thanks again to BB who came up trumps on this one! Cheers again mate! :D :D
Postby ptjs1 » Thu Jan 22, 2015 11:33 pm
David,
Great job, well done! Looks good with new components and paint!
You could do a lot worse than use your Jaguar dealer if you trust them. My local dealer did a full aircon service on my XJS which naturally includes evacuation, vacuum testing and recharge. I have pictures and text for a future mag article. Total cost was £79, i think?
Postby Brakebuster » Mon Jan 26, 2015 8:28 am
have you got it working yet ?
BB :wink:
used to have
