AC blower fans not working
Moderators: dhdove, davidr, BigCatXJS
P.L
Postby P.L » Wed Sep 14, 2011 12:02 pm
Hi there, I was about to work on my not working AC blower fans. The fuses are fine and I can hear the flaps moving when selecting any fan speed or switching to air-circulation. I assume this proves the AC control unit is somehow working?
However, the blower fans do not come up even when set to 'Defrost'. I tried to check the supply for the fan motors but I think I cannot access them with the blower units in place.
Any ideas what to test before removing the blower units? If not, are there any pictures available or advice on how to get them out? I thought I opened all the screws and nuts, pulled the lower flap to release it from the firewall but I cannot make the unit to move...
Thanks,
Peter
1994 XJS AJ16 Coupé Manual
almcl
Re: AC blower fans not working
Postby almcl » Wed Sep 14, 2011 7:15 pm
Once you have the fan box on the bench (two vertical nuts on studs behind a lot of the junk on the sides of the unit have to be released) have a look at the circuit board in the picture below. This may be the cause of the fan problem. There's one in each fan duct and you'll need to drill the rivets out...
Al McL
'93 XJS 4.0 - '05 X type Est 2.0D - '13 XF 2.2D Sportbrake
P.L
Postby P.L » Sun Sep 25, 2011 7:59 pm
Job almost done...
Starting on the passenger side revealed the motor's collector totally covered in black dust, most probably from the brushes. I sanded the collector and gave the whole unit a good clean. Surprisingly, the circuit board looked pretty good and is working fine.
Getting the driver side blower out was much easier than the passenger side. However, this time I found the usual diode corroded away beside my already known dusted collector.
Hope to get the electronics fixed soon and the whole thing back in smoothly within the next days.
To be honest, this has been the worst job in my short term of XJS ownership - so far... ;-)
ng4xjs
Postby ng4xjs » Thu Sep 29, 2011 1:32 pm
Trick is in putting them back. You will need to hold the flap open to make sure it engages/sits properly plus plenty of advice here and elsewhere as to how to reconnect the blue ducting to the units once installed.
Nick
