Only getting cold air in the footwell
Johnscotty22
Postby Johnscotty22 » Sun Jan 13, 2019 1:20 am
Hi there. I've started getting, only cold air in the footwell the air temp to the windshield and the side vents varies if you turn the temp control.. I'm only getting used to the car as I bought it recently so haven't quiet figured out how to direct the air to the different vents.it was working fine I think!!! But definitely only cold air in footwell now!!
Thanks Scott
Re: Only getting cold air in the footwell
Postby davidr » Sun Jan 13, 2019 10:12 am
Hi there - it sounds like the distribution flaps within your air box aren't moving properly
1996 XJS Celebration Conv. (shown on the JEC stand at NEC Nov 2015)
2001 XKR Convertible
Johnscotty22
Postby Johnscotty22 » Sat Jan 19, 2019 11:52 pm
Hi. Yes I think so. Do you have any ideas on how to fix? I tried moving the dialls to all the positions to try to free them up but no luck.. could I add a lubricant into the system is wd40??
Regards Scott
poprivet
Postby poprivet » Sun Jan 20, 2019 7:53 am
I think yours is an '89 from previous posts, which has the Delanair 3 system. Have a look at:
http://www.kwecars.com/technical/jaguar ... s-and-use/
which may help you.
Al
1988 3.6 XJ-S coupe
'Remember that the value of your investment can plummet as well as fall'
