Tyre pressure loss
Moderators: mg600, Jaguar2010
dglick
Tyre pressure loss
Postby dglick » Tue Nov 13, 2018 8:33 am
I have a 2015 XF 2.0 diesel
IAlk 4 tyres keep loosing about 1-2 bar of pressure approx ever 2 weeks or so.
I have read that there have been problems known around leaking valves.
Alical mobile tyres expert thinks there is a known problem of how the tyres are attached to the wheel , and a gap between the rim. They say they can resolve at £20 per tyre.
Any thoughts anyone? Has anyone else had / resolved same problem. Any advice appreciated.
Dan
Re: Tyre pressure loss
Postby J44EAG » Tue Nov 13, 2018 1:01 pm
Any decent tyre fitting bay will thoroughly clean the rim bead and brush paint on a rubber sealing compound. Tyre fitting then proceeds and the sealer is forced into any gaps between the rim and the tyre. I had four new tyres fitted over a year ago and the fitters used this methodology. A year after fitting, I`ve not had to adjust tyre pressures once. Those guys did a great job.
£20 per tyre seems excessive to me. At least Dick Turpin wore a mask..... I`d change tyre fitters and find another hopefully with a more helpful attitude.
RichardSEL
Postby RichardSEL » Wed Nov 14, 2018 9:49 am
Mobile tyre fitters will charge more than Syd Snott & Son (on the corner of Peckham Broadway and Gas Works Alley)
My lot down in Crayford charge £12.50 per wheel and that includes balance and new valve.
They're good boys. They take cash :mrgreen:
In trim shop for total refurb: '73 Owen Sedanca 4.2L
Stalled in storage '61 Mark IX with 4.2L
poprivet
Postby poprivet » Wed Nov 14, 2018 11:40 am
I had a spell where the tyre valve / alloy wheel developed minute leaks. I 'borrowed' my nephews blowing-bubble solution and used it neat on the area, after a few hours it developed into fine foam.
A local tyre fitter replaced the valves and cleaned the degraded paint very cheaply. Many of the tyre fitters will do this on the side for a drink.
1988 3.6 XJ-S coupe
'Remember that the value of your investment can plummet as well as fall'
