IMPERIAL LENS SCREWS
Moderator: XjRestorations
dg4cars
Postby dg4cars » Tue Jul 05, 2011 11:23 am
Looking for help here - my 1973 Series 1 XJ6 is missing a few screws in various external light fittings eg. indicator lens and reversing light. I am finding it impossible to get imperial screws and the metric ones are not the right size. Has anyone any advice please
Re: IMPERIAL LENS SCREWS
Postby J44EAG » Tue Jul 05, 2011 11:29 am
almcl
Postby almcl » Tue Jul 05, 2011 1:33 pm
Away from the garage at the moment so can't check but I *think* the screws/bolts etc are BA threads. If a google search doesn't turn up a supplier nearby, your local model making shop may be able to help if you take a sample along.
Going out even further on a limb, the BA thread is actually metric based, so it is just conceivable that a similar, slightly smaller metric bolt may be persuaded to fit.
Al McL
'93 XJS 4.0 - '05 X type Est 2.0D - '13 XF 2.2D Sportbrake
dg4cars
Postby dg4cars » Tue Jul 05, 2011 2:59 pm
Thanks guys for advice will follow up. By the way Mike I thought rear bushings were your speciality !!! Derek
Postby Brakebuster » Tue Jul 05, 2011 7:03 pm
4mm metric will fit into a 2BA thread, and hold quite well,
and the ' Pan-Head ' screws look quite good, you can get them in brass or chrome/nickel plate
it was used in my electrical trade,
however,
the 2BA wont go into the 4mm , never........
2004 2.1V6 X-Type Saloon in platinum silver for the good wife
used to have
1999 4ltr Sovereign XJ8 in Seafrost
XjRestorations
Postby XjRestorations » Sat Jul 09, 2011 8:24 am
If you have the JDHT workshop/Parts manual - flick through and find the part number of the fixing you require. Then give SNG Barratt a call. You will be amazed at what they have that are either genuine, or a cross referance part!
555ttg
Postby 555ttg » Sat Jul 09, 2011 7:54 pm
If you're still looking for the oem parts, PM me and give me the list, I have LOTS of series parts either NOS or 'gently used'. Postage from Canada, isn't that expensive.
Phil
1973 Series 1 XJ12 SWB
1977 Series 2 XJ6C
1987 XJ-S 5.3 litre auto Cabriolet
1989 LISTER modified XJ40
1993 XJS 4.0 litre Manual facelift
tom_langley
Postby tom_langley » Tue Sep 01, 2015 3:41 pm
Gent's,
I've just used the info on this thread to source a couple of parts, many thanks, very useful.
After phoning the main parts suppliers; David Manners, SNG Barratt etc, I eventually found the parts I required from Martin Robey & JDHT.
Thanks again for the useful information.
