X300 Brake Pad Replacement
Moderators: robv12, Popsjag, h18spk
jBlackwell
Postby jBlackwell » Mon Aug 01, 2011 3:35 pm
I am about to replace the rear pads on my X300. As a novice mechanic is there anything I should be keeping an eye out for?? All hints and tips appreciated.
James
robv12
Re: X300 Brake Pad Replacement
Postby robv12 » Thu Aug 04, 2011 12:07 pm
james, it's simple nuts and bolts, just be aware that a 300 is two tons of car, it will hurt you if it falls on you, ensure the car is chocked abnd supported on axle stands on FIRM ground, take your time, do one side at a time and you will be fine
if in doubt use the Jaguar Heritage DVD to guide you through, or of course call me!
88 3.6 XJ40 EX JDHT
88 3.6 XJ40 SOV
93 XJ40 XJ12
94 XJ40 3.2 Majestic Gold
93 XJ40 XJ6 3.2 paint test car
97 XJR 300 Manual
97 XJR 300 Manual EXJDHT
55 XTYPE EST 3.0 SP PREM
62 351 LWB PREM LUX
jBlackwell
Postby jBlackwell » Thu Aug 04, 2011 1:51 pm
Hi Rob,
All successfully done. Car was suitably supported, I had enough scares of cars on axle stands ( A Q7 on four axle stands moved, unbalanced, and supported by me, and some plaintive cries of "help" still haunt me).
Pads replaced and is now all quiet and none grinding :)
Thanks for your offer of help :)
