cruise control
Moderators: robv12, Popsjag, h18spk
greenie60
cruise control
Postby greenie60 » Tue Mar 12, 2019 6:46 am
cruise control doesn't work in my '87' Daimler.
switch operates and red light comes on but no cruise control.
where do I start, I was thinking of looking/replacing the bellows in the throttle lineage area first.
any suggestions please
steve_m
Re: cruise control
Postby steve_m » Tue Mar 12, 2019 2:29 pm
Mine is exactly the same so any help out there gratefully received.
davidr
Re: cruise control
Postby davidr » Tue Mar 12, 2019 8:37 pm
I think the X300 has the same system as my very late XJS. Mine didn't work and I found the issue to be vacuum dump valve sticking open. Replaced it with a used one and all good
1996 XJS Celebration Conv. (shown on the JEC stand at NEC Nov 2015)
2001 XKR Convertible
greenie60
Re: cruise control
Postby greenie60 » Tue Mar 12, 2019 8:48 pm
the 'vacuum dump valve', is that the bellows type thing in the throttle linkage, top of the engine mid point left hand side ?
davidr
Re: cruise control
Postby davidr » Thu Mar 14, 2019 8:49 pm
I've attached a picture of the components. The dump valve is item 2 on the diagram.
steve_m
Re: cruise control
Postby steve_m » Thu Mar 14, 2019 9:11 pm
Thanks David.
greenie60
Re: cruise control
Postby greenie60 » Fri Mar 15, 2019 6:42 am
thanks david, that's just the schematic I needed
greenie60
Re: cruise control
Postby greenie60 » Sat Mar 23, 2019 6:05 pm
when for a warm up run today, tried the cruise control at about 70 mph and it worked. turned it on and off again at it still worked but didn't work again after that.
is there a minimum speed it should work out i.e 50/40 mph ?
Zennan101
Re: cruise control
Postby Zennan101 » Sat Mar 23, 2019 6:31 pm
Hi Greenie60,
I am not clear from your post if you turned off the Cruise Control and then tried to turn it on again or if the Cruise Control turned itself off (if you hit the brakes for example) and you were trying to Resume the Cruise Control or if you were driving faster than the set speed ...Overriding the Cruise Control or perhaps going downhill....There are different responses to each scenario.
Certainly you should be able to set the Cruise Control at 50 or 40.
Rod
2010 XF 3.0 Luxury Diesel
greenie60
Re: cruise control
Postby greenie60 » Sat Mar 23, 2019 9:32 pm
i purely just tried switching it off then on again which worked twice but when I tried it again about a mile later then it didn't work at all.
I didn't touch the brakes just the switch and it didn't turn itself off
