Fitting seat belts to a 1968 Damlier Soverigh
Moderators: Aceman, ecosselynx
cotoole
Postby cotoole » Mon Jun 14, 2010 9:33 am
can anybody tell me if there is a know way/supplier of seat belts for a 1968 damlier soverign.
I am a member based in ireland.
Is there a know way/specification for how to fit the bels or a supplier who supplies them.
Many Thanks
Chris
Postby J44EAG » Mon Jun 14, 2010 10:13 am
Chris,
This company appear to supply belts for your car.
http://www.securon.co.uk/
Might be worth contacting them.
suarthardy
Postby suarthardy » Tue Jun 15, 2010 8:46 am
Hi Chris
If your car is a 420 Sovereign then I think the seat belts are the same as for the Mk2 and the S Type. I have a 420 and feel sure this is the case. I can check the part numbers from my parts catalogue if you want.
SNG Barratt do a good range of seat belts and can give you the choice between static and inertia reel types. They sell Securon belts too but you might save some money by going direct if possible. I don't know whether Securon belts would look original, if that's important to you.
There is also a company called Quick Fit (NOT the well known chain of car repair specialists) who specialise in seat belts for classics and come highly recommended from the classic car press. Try this link
http://www.quickfitsbs.com/index.asp
although you would probably need to visit to get them fitted.
Good Luck
Stuart
cotoole
Seat Belts
Postby cotoole » Wed Jun 16, 2010 5:18 pm
Many thanks guys
Chris
